Kpro ecu compatibility
emooheo
Post by emooheo »
I am looking to purchase a core ecu to install kpro for my eg coupe k swap (k20z3 w/ 05 civic 5 spd trans). I wanted to confirm my understanding before purchasing
I referenced https://www.hondata.com/tech-alternativ ... ngine-swap and https://hondata.com/kpro-product?route= ... uage=en-gb and found a 37820-PPA-A54 ecu, will this work for my swap and kpro core?
Thanks in advance
emooheo
Re: Kpro ecu compatibility
Post by emooheo »
I also wanted to confirm if this would be plug and play with a hybrid racing conversion harness (after kpro installed).
Yes it should work, but you will still need to make the changes as stated in the link about alternative ECU for K-Pro.
emooheo
Post by emooheo »
Spunkster wrote: Mon Dec 02, 2024 3:24 pm Yes it should work, but you will still need to make the changes as stated in the link about alternative ECU for K-Pro.
Thanks for the reply. To confirm my understanding, I need to do this because its an auto ecu right? If i were to find a manual then it would work without extra wiring?
Correct
