having issues with injector ms drops and afr leans out
payam_fox
Post by payam_fox »
hey im tuning this h22a4 turbo and when i floor it right around 18-19 psi injector ms drops and afr drops can anyone help with this ?
i have uploaded the datalog
Re: having issues with injector ms drops and afr leans out
Post the calibration used to make the datalog.
payam_fox
Post by payam_fox »
hi here is the calibration
Try disabling the launch control. You have it set to always on and that may be the cause of this.
payam_fox
Post by payam_fox »
oh yea that was the problem , i was trying some rolling launch and forgot that launc control speed , thank you so much , i also have idle issues when cols start it , idle wont stay up i have to keep the gas so it warms for 1-2 mins and then idles to 800 not even going up when i change the corretions or play with idle setting .
You may need to clean the idle controller.
payam_fox
Post by payam_fox »
thank you so much , that was a big help
