FlashProManager 4.3.9
FlashProManager 4.3.9 (23 Dev 2024)
  • [Spoon Sports] Added Stage 3.5 calibration for N-One 2023 CVT JG3 RS Japan
Download here
William.Y
Re: FlashProManager 4.3.9
Post by William.Y »
UpLoad fail , FL5-110 , ECU No. J03 , Flash Pro Serial No. 371648.
''send feedback'' sent. Please check what happen, can not upload with J03 and J02 ECU, many thanks.
It works here. Does return to stock work? In that case it would be the jailbreak.
William.Y
Post by William.Y »
thanks for reply, will try again later
William.Y
Post by William.Y »
Hondata wrote: Mon Jan 06, 2025 9:28 am It works here. Does return to stock work? In that case it would be the jailbreak.
Hi, is the jailbreak procedure same with the FL5-110 JDM version ? And dose it need to change the CAN Gateway ?
Jailbreak is the same. If the gateway has a part number ending in JA1 then it needs to be changed.
William.Y
Post by William.Y »
Hi , If change the can gateway, it will gives VSA errors. Can the HONDATA CAN Bridge use on the FL5-110 ? Or any other solutions ?
Yes, it works on the FL5-110. Probably still 3-4 weeks away from that release.
William.Y
Post by William.Y »
Hi , has it been released yet?
And I have problem with flashpro manager during register after update to 4.4.5.0, it shows [check you have a internet access] , and my network is 100% no problem.
Not yet. Soon. Parts delayed by the new tariffs.
