Analog inputs to fuel table?
Hello I'm am try to figure out if there is a way to get my analog inputs to display on fuel tables for fuel adjustments and what not. I have a AEM WIDEBAND 30-4110 . I wired it up to analog input 0 I got it pretty accurate reading to show on "display" but I would like it to show on the fuel table is there anyway to do so with it wired to analog input 0
Re: Analog inputs to fuel table?
It would be best to use the ECU inputs instead of the analog inputs on the s300 as then it can run closed loop and have full functionality.
Could I get away with just taping the "white" 0-5 volt output from the wideband to the d14 pin or would i have to re wire both ground and power from the wideband to the ecu as well?
Power and ground do not matter. You should use D10 instead of D14 as it cannot read the full voltage range.
How will using the d10 impact negatively or the side effects if you will? I just wanna understand before I got tapping in to wires
There are no side effects. Details can be found in the help file at: https://hondata.com/help/smanager/wideb ... b=wideband
lester1968
Hi. To use the ECU input on D10, is it necessary to remove two resistors, as I’ve read, or is that perhaps no longer required?
Yes, this is recommended.
