2006 TSX 6 Speed Driveline Swap
Maritime Guy
Post by Maritime Guy »
I have a non Honda chassis and a 2006 TSX 6 speed donor car.
I’m finding conflicting information about the ability to use the engine wiring/ecu with KPro and looking for some clarification.
Thanks!
Re: 2006 TSX 6 Speed Driveline Swap
The TSX engine harness and ECU is not compatible with the K-Pro. You must use an 02-04 RSX ECU and engine harness. IT must also be converted from drive by wire to a cable throttle body.
Maritime Guy
Thanks for the clarification!
One further question if I was to use a 02-04 manual CRV or Element harness instead of the RSX one would that work? The RSX ones seem to be fairly rare in my area
CRV may work, but untested. Element will not work.
