idle goes up and down after release throttle and volt drop when heavy load
Bowo gono
Post by Bowo gono »
hi hondata..
im using hondata v3 with blok b20, head b16, stock inj, fuelpress 43,5 psi, fuel pump walbro, piston wiseco
im having trouble with idle up and down after release trhrottle..
and when heavy load like light on, ac, power steering idle drop.. (duty iac has been added has no effect)
Re: idle goes up and down after release throttle and volt drop when heavy load
With the idle controller unplugged what does the engine idle at?
Bowo gono
Post by Bowo gono »
problem solved, wrong inj deadtime
