SManager V2.8.8
SManager V2.8.8
SManager V2.8.8 (16 Jan 2025)
  • Added closed loop inactivity timeout
  • [S300 V3] Firmware version 23
  • [S300 V3] Fixed ethanol disabling after ECU power cycle.
Download here
Please only reply to this thread with issues & questions specific to the changes in this release. For all other problems start a new thread under the appropriate vehicle category.
DatLife84
Re: SManager V2.8.8
Post by DatLife84 »
Just updated to the v2.8.8 and now cannot change the values in Pressure vs Duty Cycle in the boost control tab.
Re: SManager V2.8.8
Post the calibration you are trying to make changes to.
1 bad em1
Re: SManager V2.8.8
Post by 1 bad em1 »
Is the 'closed loop inactivity timeout' intended to fix the issue where closed loop becomes inactive/freezes/quits working? And if so, do we simply raise the timeout value to help alleviate the problem?
The power of dreams
DatLife84
Re: SManager V2.8.8
Post by DatLife84 »
Spunkster wrote: Mon Jan 27, 2025 10:18 am Post the calibration you are trying to make changes to.
Ek Turbo 1 (15psi 9k).skl
1 bad em1
Re: SManager V2.8.8
Post by 1 bad em1 »
Hondata wrote: Thu Jan 16, 2025 8:01 pm SManager V2.8.8 (16 Jan 2025)
Download here
Let me know when you have a chance about the 'closed loop inactivity timeout', is this intended to resolve the issue where people have their closed loop stop working (typically after deceleration/full lean/tip out)? I believe it was something to do with the ECU thinking closed loop was malfunctioning due to the o2 reading being too high for too long, so maybe this 'inactivity timeout' value is supposed to increase the length of time before the ecu disables closed loop? Let me know if that is correct, I had this problem happen a few times but it is random, if this resolves that problem that would be great.
The power of dreams
Re: SManager V2.8.8
DatLife84 wrote: Sat Feb 01, 2025 6:05 am
You do not have the gear based target boost selected.
Re: SManager V2.8.8
1 bad em1 wrote: Sun Feb 02, 2025 10:52 am
Download here
It may help. Try it and see if the issue continues.
1 bad em1
Re: SManager V2.8.8
Post by 1 bad em1 »
Spunkster wrote: Mon Feb 03, 2025 11:02 am
Download here
It looks like this was indeed intended to fix that issue that was noted by several people in 'closed loop malfunction' thread. Hondata admin posted in that thread that this release exposed that timeout value to try to eliminate the problem. I'll be testing it out once spring rolls around, glad to hear it! It's been several years of this problem so I'm happy to hear something is finally being done to try to fix it.
The power of dreams
DatLife84
Re: SManager V2.8.8
Post by DatLife84 »
Thank you
