Injector Time Dip
NateDawgST
Injector Time Dip
Post by NateDawgST »
Hello. Probably an easy one, but I have a 2007 s2000. I see there's a little dip in injector time, i was just wondering if its suppose to be like that and its normal for s2000. Car has been tuned before, i was doing datalogs after making swapping parts out, and i noticed the injector time dip. It does lean out the recorded afr to around 14 at that one spot in the rpm range, then goes back up to around 13 and is normal again. Does this need to be corrected? Im not too familiar with messing with injector times. Thanks
NateDawgST
Re: Injector Time Dip
Thought i attached pic
What injectors are being used?
NateDawgST
just factory 310cc
You need to post the calibration used as well as a datalog showing the issue made using that calibration.
