does K-PRO work on RSX base A/T?
dailyCRV
Post by dailyCRV »
Wow! Looking over Hondata product pages, I just found out there is a Hondata Reflash for RSX base A/T. And so on to the Reflash FAQ, i saw at the very bottom it say's
"What about turbo-charging and super-charging?
Use the K-Pro or FlashPro."
Does this mean K-Pro now works on RSX base A/T?
Is RSX base A/T tunable now with K-Pro?
Please advise.
I have a daily driven 2003 CRV A/T. It is stock k24A1 block with K20A2 head/intake manifold/throttle body. There is no check engine light, no codes. I been running it with Greddy Emanage piggyback. It runs great after VTEC kicks in at around 3,000 rpm, picks up no problem. But I can not get the Greddy Emanage to tune right under 3,000 rpm cruising. It is sluggish under 3K rpm. I have been hoping for a long time Hondata makes K-Pro work for K series A/T, did it finally come forth.
Re: does K-PRO work on RSX base A/T?
No you cannot use the K-Pro on an automatic vehicle.
dailyCRV
Post by dailyCRV »
Thanks for the reply. Yup, I did not think K-Pro would work.
