correct wiring ot not ?
Nusmi
Post by Nusmi »
Hi,
is my diagram correct for my wiring? or are there things wrong and need to be corrected ?
wiring with O² sensor, second air temperature sensor, oil temperature sensor and boost solenoid (MAC )
I have a doubt about the resistor in parallel in D19
https://hondata.com/help/smanager/analo ... rature.htm
https://hondata.com/forum/download/file ... d5905fe8c6
Re: correct wiring ot not ?
Is there a problem you are having with it?
Nusmi
Post by Nusmi »
Hello, it is to know if everything is correct before doing the wiring. and burning something....
the resistors in D19 are good ? in parallel ?
( so for exemple : if 2 sensor = 2 resistor / if is 3 sensor = 3 resistor / etc.... )
ths same for ground D21 ? all sensor added are connected at this point D21 not to D22 (map ground) right ?
thank's
It looks ok from what I can tell.
