FlashProManager 4.4.2
FlashProManager 4.4.2 (17 Feb 2025)
  • [FK2/FK8/FL5/DE5] fixed torque limit table re-load
FlashProManager 4.4.1 (14 Feb 2025)
  • Firmware updated to version 253
  • [FK2/FK8/FL5/DE5] added bosch tables
  • [FL5] 66V-A06 added extra datalogging sensors
  • [FL5] Added support for 66V-Y03 binary (66V-Y04 ECU)
  • [CRV] Added support for 5PD-Q94 binary Indonesia
  • [2024 Civic CVT] Running fix for 64A-AG2
  • [2018+ Accord 2.0T] Added CANFlex support
Download here
FK8_Hoonigan
Re: FlashProManager 4.4.1
Post by FK8_Hoonigan »
There is a bug on 4.4.1 and the Torque Limit table
Any value entered on this table, will not stick.
If you edit the table, lets say to 99% and SAVE, CLOSE and Re-Open the calibration, the table will open with random low values such as 13.7% and the user's car will be without power as a result.
GARIX Tuning
2021 R-39464
https://dot.cards/garix
jeffx
Post by jeffx »
FK8_Hoonigan wrote: Mon Feb 17, 2025 7:03 am There is a bug on 4.4.1 and the Torque Limit table
I'm seeing the same bug. It seems that it's taking whatever you enter, dividing that figure by 655 and then expressing it as a percentage.
As a test, I put these values in the table, then saved the calibration and closed it.
When I open that calibration, these are the values that were saved
MT_Tuned
Post by MT_Tuned »
Not just that error in the torque tables… I sent multiple revision updates to different clients with minimal adjustments in timing and the boost by gear table, and all of them ended up with no throttle response—they couldn’t accelerate.
They all had to perform the update to load my revision, and after that, they all reloaded the previous map, and everything went back to normal.
Apologies; this has been fixed.
Fkay8
Re: FlashProManager 4.4.2
Post by Fkay8 »
Is it possible to give some kind of intruduction of the new tables?
They are advanced tables. If you do not know what they are, then you do not need to change them. For instance, if you change the nominal charge or optimum torque then your vehicle is going to generate torque interventions and shut the throttle.
https://hondata.com/help/flashpro/bosch ... _model.htm
https://hondata.com/help/flashpro/torque_parameters.htm
