No live data s300 irregular idle
KRKron
Post by KRKron »
Installed Burton COP and P28 with s300 V3 in a 1998 Honda Prelude. Stock H22a base map. It runs but idle is irregular after is running for a few seconds. I was getting live data to read after installing, but after turning everything off, exiting s300, etc and trying to troubleshoot the idle issue at a later time, now I'm getting no live data at all. It's been about a week between the initial install/seeing the live data vs the current issue. running base h22a tune. engine is stock besides euro r manifold.
During initial install, I messed up and didn't de-pin A21 on the ECU. I only attempted to crank once before I realized that. i shut the car off and performed de-pin then vehicle ran w/ live data showing but did not have time to troubleshoot idle issue. This was prior to the above issue coming up. I know this could have fried the Apollo board, but it did crank and run after depinning A21 and I had live data just bad idle.
Re: No live data s300 irregular idle
Have you discussed this issue with the manufacturer of the COP kit?
