WOT Lambda adjustment table
dennis si
Post by dennis si »
How do I add boosted columns to the WOT Lambda adjustment table? I'm sure there is a way... I'm on the 1000cc DW injector starting calibration.
Re: WOT Lambda adjustment table
What vehicle are you referring to?
dennis si
Post by dennis si »
06-11 8th gen us. 09 specifically. Started with the DW1000cc injector basemap and the WOT low and high only show 10 columns. I right clicked but it won't let me add any columns like I could in low/high fueling. I have column 10 ".2" set to 11.64 afr so anything above that will go off column 10 I am guessing? 6262 turbo stock k20z3.
dennis si
Post by dennis si »
I have show all columns under options selected and all 20 are there in fueling, just not WOT lambda adjust.
dennis si
Post by dennis si »
As I was typing I realized I can increase resolution for fueling since I am maxed out at 8 psi on my wastegate spring. Score!
dennis si
Post by dennis si »
I guess I might as well adjust my low cam fueling resolution as well and get to using the autotune feature again. I am right better resolution closer columns will increase the ability to get fueling spot on and lower short term fueling, yes? Or is it not worth it?
