Turbo LS-Vtec base map needed
MrMikeLee
Post by MrMikeLee »
Ls-vtec
AFI ramhorn s362 turbo
44mm precision WG
3 port Mac boost controller
B16 head, Bc TI springs/retainers
Skunk2 stage 1 tuner cams
81.5 Traum turbo pistons 10.25:1
Turbo Tuff rods
epoxy block
ARP hardware on head,Rods
AEM fuel rail/regulator
4 bar omni Map
1500cc huntertuned injectors
91oct fuel WB450 in tank
hondata s300v3
just looking for base to drive to dyno.
Have AFR, Boost and ethanol content gauges
CalibratEd
Re: Turbo LS-Vtec base map needed
Post by CalibratEd »
Have you tried reaching out to your tuner? They may be able to send you a base calibrations to get you to the dyno.
-Ed
Instagram: calibrated.tuning
