Hybrid racing cai tune
teves17
Post by teves17 »
Hi i have a 2006 honda civic si and iv have recently purchased and installed a hybrid racing cold air intake. In doing so i have found a base map tune using these forums and was just curious if i could get some some assisting getting a proper tune dialed in so I can get the most out of it and have reassurance that the tune i have on now if safe for the car
CalibratEd
Re: Hybrid racing cai tune
Post by CalibratEd »
Post the calibration file you are running along with a datalog. I can take a look at it and let you know how it’s running.
-Ed
Instagram: calibrated.tuning
teves17
Post by teves17 »
sounds good thanks, I have attached my current tune and a 15 minute driving datalog. I did some small pulls and also included a 3rd gear wot pull. just for some background info I have the hybrid racing cai, stock header with no cat, stock exhaust to an aftermarket axle back to ktuned muffler.
teves17
Post by teves17 »
I’m also not sure if this is important or relevant for when you look at the datalog but I do have a small evap leak.
CalibratEd
I suggest you fix all mechanical issues as they can affect the way the car runs. There is no knock which is good however the car is running lean. You need to add fuel to the tables.
-Ed
teves17
Post by teves17 »
Okay thank you I’m wondering if it’s possible for you to help me with fixing the tune as I’m not sure how to add more fuel so that it doesn’t run lean
CalibratEd
I suggest you add 10% fuel to all the fuel tables.
I will look it over again when I have some downtime.
- Ed
CalibratEd
I added 10% fuel to all the tables so it would not run so lean. Create another log with the new file so I can make sure the changes took effect.
-Ed
