FlashPro Tuning - Shifting of Torque Curve to Lower RPM
Hondasingapore
Post by Hondasingapore »
Hi, Experts out there:
What is the recommendation(s) or is it possible at all in terms of FlashPro tuning so the torque curve will not seen a dip, says between 3000-5000RPM for my 2008 JDM Honda Civic Type R, FD2? I have yet to feedback to my tuner, but preferably, I want to get second opinions wide in this forum first.
My focus is low-to-mid RPM shove/torque as my car is a daily-driven car. My VTEC crossover is currently at around 5850RPM.
Please see the attachment which is my latest dyno chart for the torque. Some personal information has been cropped.
Thanks.
SK
Re: FlashPro Tuning - Shifting of Torque Curve to Lower RPM
If the dip is because of the torque curve from the low speed then high speed cam lobes, then ECU tuning cannot change it.
Hondasingapore
Hi, Hondata:
Thanks for the technical explanation. I will talk to my tuner soon after I swapped to a J35 throttle body and slightly bigger airbox.
Cheers.
SK
