FlashProManager V4.4.4
FlashProManager 4.4.4 (24 Mar 2025)
  • Firmware updated to version 257
  • [FK8] added extra datalogging sensors
  • [CanFlex] Fixed MIL with older FlashPro under some conditions
  • [2016+ Turbo Civic] Added support for 2020 model 5AW-TG1 Turkey
  • [2018+ Accord 1.5T] Fixed no start issue
Download here
Ziradon
Re: FlashProManager V4.4.4
Post by Ziradon »
Hi,
can you specify the extra datalogging sensors for the FK8?
And do they work with just updating the flashpro or is reflashing the map to the ecu necessary?
Thanks,
Thomas
2020 Honda Civic Type R - European Edition
The ECU has to be reflashed.
'Trq Req' = torque request
'Act Trq' = actual torque
See the help file for more information on those
https://hondata.com/help/flashpro/torque_parameters.htm
https://hondata.com/help/flashpro/bosch ... _model.htm
Additional channels for helping diagnose torque limits in high hp vehicles (over 600 hp)
'trq_max', 'arc_max', 'airc_red'
jeffx
Post by jeffx »
Hondata wrote: Tue Mar 25, 2025 10:02 am The ECU has to be reflashed.
THANK YOU VERY MUCH!!!
FK8_Hoonigan
Post by FK8_Hoonigan »
MUCHAS GRACIAS!!!!
This will be very handy for us!
GARIX Tuning
2021 R-39464
https://dot.cards/garix
FK8_Hoonigan
Not being picky, i appreciate all the hard work....
Just pointing it out in case it flew under the radar... The "tracer" marker on KFMIRL table for FK8 doesnt show for the column/row
GARIX Tuning
2021 R-39464
It is no problem; simple to fix.
Fkay8
Post by Fkay8 »
Hello Hondata, just a question regarding a new datalog value (torque request), on my calibration I have on the torque request table a value of 500nm (~83%) but on the datalog torque request value shows 87% (522nm).
I'm not uderstanding why this diference, doesn't this value should be same on my request table of my calibration?
The aircharge max is correct with my calibration table.
jeffx
Post by jeffx »
which car? FK8? FL5/DE5? Probably should post this question in the Type R 2015+ forum and provide more specifics
Fkay8
Post by Fkay8 »
jeffx wrote: Sun Mar 30, 2025 9:53 am which car? FK8? FL5/DE5? Probably should post this question in the Type R 2015+ forum and provide more specifics
FK8
AllenZhangFE3
Post by AllenZhangFE3 »
I've been eagerly awaiting the release of this version for a long time, but unfortunately, it still does not include support for my car model. Ever since I sent the original factory program to Hondata in December last year, I've been on a long wait. I'm very eager to know whether the 37820-6KA-H030 will be supported in the next version. Thank you very much for all your work.
Please send the file again.
Is this a hatchback?
AllenZhangFE3
I have attached the stock program and description file that I read using PCM Flash. This is a Chinese domestic sedan, and I am very sure that it belongs to the same generation as the 37820-64C-H01 (hatchback) that Hondata already supports. If you need further information, I can send it to you via email. Back in February, Matt told me that support would be added in about a month or more. I hope it will be updated in the near future. Thank you very much!
AllenZhangFE3
So, can we look forward to the next update? Thank you!
Our software engineer is working on this.
