VSS input
tom_h02
VSS input
Post by tom_h02 »
Hello, New member here.
I'm doing a K24A swap into a non-Honda chassis. Transmission has no VSS sensor (old classis car).
I will be using a 55505 Hall Effect sensor. I'm using a PND ECU from a base 02 RSX auto. I'm aware that the VSS signal goes to directly to the Kpro board instead of pin A18.
From other threads I learned that the new VSS signal has to be a sinking output with a pull-up resistor. The 55505 hall effect sensor seems to have these characteristics. Can someone confirm that I can use this sensor for the VSS input? The spec sheet even says that the sensor has an internal pull-up resistor. See pics attached.
tom_h02
Re: VSS input
Post by tom_h02 »
Which of these circuits is correct for the VSS input?
Re: VSS input
Probably best to power the sensor with 5V and then you don't need the additional transistor.
tom_h02
Re: VSS input
Post by tom_h02 »
Sounds good. So, basically the signal goes directly from the sensor output (internal pull-up resistor) to the Kpro VSS input.
Re: VSS input
Should work as the sensor shows an internal pull up resistor.
