Can you run a NonVtec program on a P28?
sander
Post by sander »
The reason i ask this is that i used to have an LSvtec, and now have a b20, i was wondering if i could just disable the vtec pressure and spool and just use the low speed tables of the P28?
Thanks,
-sander
learning.
Yes, in the software disable the VTEC pressure and spool, and disable the use of the high speed cam table.
sander
Post by sander »
Great thanks.
-s
learning.
Super-Tuner
Post by Super-Tuner »
how do u disable the high speed cam table or do you just not use it and ignore it?
DaX
Post by DaX »
You can set the RPM at which the High Speed Cam Table engages at an unattainable RPM...like 11K RPMs.
Super-Tuner
Cool, also should you check the box under the vtec tab that says non vtec? Im assuming yes. Also what do you do with the iab section just set it to like 8000 like the rev limiter or what
