Good afternoon guys,
Currently about to finish my swap but I am way over budget and really cannot afford a professional tune for a while.
Hoping to get some guidance or if someone can show me how to tune it well enough to still be dailyable, AND KEEP THE ENGINE SAFE.
I bought a low mile 40k estimated K24A and really want to protect it...
Here are my specs...
K24A from a 07 tsx, (later model that has the little bit higher end engine)
50 degree vtc gear
Rsx type s throttle body, 62mm bore, but plan to bore to 64mm to match the 07 rbb manifolds 64mm. (I am using a skunk 2 72/74mm adapter plate)
Hybrid racing intake system, which is a 3" tube with 3" velocity stack and filter
Skunk 2 Alpha 4-2-1 header, for a 02-06 rsx
skunk 2 mega rr 76mm exhaust for a 02-06 rsx
5 speed k20 ep3 transmission
oem exedy clutch
Stock fuel, Oem spark plugs, everything else not mentioned is stock.
I will have a High output alt if that matters.
Let me know how yall can help, i would appreciate it.
JDM K24A Tune Help
- CalibratEd
- Contact:
Re: JDM K24A Tune Help
I suggest you start by using the stock tsx calibration. It’s will not use the 50vtc but you can dial it in to get the car running until you get it properly tuned.
-Ed
-Ed
Instagram: calibrated.tuning
IWannaBeFastTooMom
Are there any resources on how to dial in a tune? i am a complete noob at this.
Thanks!
Thanks!
- CalibratEd
- Contact:
YouTube has a variety of videos. Check out evans tuning on YouTube. He has some pretty good videos.IWannaBeFastTooMom wrote: Mon Mar 31, 2025 8:24 am Are there any resources on how to dial in a tune? i am a complete noob at this.
Thanks!
-Ed
