Hi,
I have a problem to control boost with my Twin 44m.
Running Hondata 4port solenoid
I plugged ad this diagram below with a T
https://www.hondata.com/images/hondata_ ... ctions.pdf
and can't control my boost, that makes no sense at all I barely get 2 or 3%, Either 1 b or 3b
Could you confirm that Hondata 4port Solenoid need to be set as a normally open in S300 boost control ?
Is the plugging correct ?
Thank you for your help
Boost Control
Re: Boost Control
It needs to be set as normally closed.
Steeve_Civic
Re: Boost Control
Thank you,
And plugged as below for Wastegates ?
Steeve_Civic
Re: Boost Control
Does it work also if I set normally open and invert connections A&B on wastegate ?
Re: Boost Control
It should come with a diagram to show how it needs to be plumbed in the package with the solenoid.
Steeve_Civic
Re: Boost Control
Hi,
It works with normally closed and std diagram
Thks
40% I'm around 23-25 PSI
Thks
