Hi,
Could you advise me any Coolant pressure sensor and wiring / parameters to S300 V3 ?
Thks
Coolant Pressure wiring and advises
Re: Coolant Pressure wiring and advises
Details can be found in the help file at: https://hondata.com/help/smanager/analo ... sub=analog
Steeve_Civic
Hi,
Just Bought and fixed the AEM pressure sensor #30-2130-150.
Could you please assist me to configure it on the Analog input ?
Which voltage should I put I can also put 2 values.
Thks
Thks
You will need to enter the voltage calibration numbers that came with the sensor.
