Datalog - MAP value changed
CHB
Post by CHB »
Hi Hondata,
I recently changed the MAP Sensor Value in reviewed my datalogs "Option - Sensor" from default to displaying "PSI Display max = 50psi". After the change I review my the datalog again but the graph is now show unexpected max boost of 22psi (as oppose to 10psi before I change the Sensor Display Value.
I am now in a situation where I have doubts on the datalog file for any realistic analysis.
What is the default value for the MAP Sensor Display Min and and Display Max?
I have attached the cal and datalog file for your reference.
04042025_6.3psi.kal
Boost cut 05042025_SesssionLast.kdl
Re: Datalog - MAP value changed
The min and max will not affect how it reads it just allows you to change the minimum and maximum it displays.
min: -29.92
max: 15
