Question about Accord 2.0 CANflex
justtuneit
Post by justtuneit »
So I wanted to get flex fuel for a while I was going to pull the trigger last fall on the prl version but then found out it doesnt do real time adjustments to fuel you put into the car. You have to do a mix of fuel to get the right % would canflex for the accord 2.0 Allow you to run straight e85 with out mixing it if its tuned? atm im on ktuner tune. So thats another question would I need to get honda data to run this or could it run on ktuner? Also is the unit able to run real time adjustments if I were to run 87/91 then wanted to run e85 for a more spirited drive?
Re: Question about Accord 2.0 CANflex
CANFlex only works with FlashPro. Then you can run any blend from E0 to E100 and it will adjust the tuning for you in realtime.
justtuneit
You still need a tune correct? Like if I'd get a full e85 tank I'd need a tune to run that for gains of power. But what if I put 93 in the next tank it will just revert to a none tune correct
There's a CANFlex calibration included, and it will adjust from E0 to E85 without you needing to do anything.
justtuneit
Damn thats nice as F ty so much I was so pissy I couldnt find a legit flex fuel in real time. I should of went with honda data tune form the start vs k tuner lol
