Tuner is Kinda MIA. Car was tuned on 91 and made 408 before cracking sleeves.
Had the blocked sleeved, wanting to have someone look over the tune. Plan on putting it on E85 but wanted to put some miles on the engine with 91
ive sinced turned down the duty cycle to around 9.8psi.
base timing was set at 16*
b18 ramey sleeve, Ls-vtec
AFI ramhorn s362 turbo
44mm precision WG
3 port Mac boost controller
B16 head, Bc TI springs/retainers
Skunk2 stage 1 tuner cams
81.5 Traum turbo pistons 10.25:1
manley h beam rods
ARP hardware on head,Rods
AEM fuel rail/regulator
4 bar omni Map
1500cc huntertuned injectors
91oct fuel WB450 in tank
hondata s300v3
Needing someone to look over tune.
Re: Needing someone to look over tune.
Tune looks good, except id pull 4 degrees from your low and high boost areas
