S300 rev limiter issue v2
vdgmarc
Post by vdgmarc »
Hi all, on a hillclimb Civic with B16B with S300, I have strange sporadic issues. Sometimes the rev limiter switches to on for an unknown reason. The rest of the time, everything ok.
Looking in the logging coupled with the mapping, I don't see any reason for this.
Any idea? Mapping and logging attached.
Re: S300 rev limiter issue v2
When did the problem start and what has changed on the vehicle since it was last working correctly.
vdgmarc
Post by vdgmarc »
It's there since the beginning of the engine.
vdgmarc
Post by vdgmarc »
Beginning of the engine was early '24.
If it is sporadic, then it may just be a wiring related issue. Try the ECU on a known working vehicle and see if it works correctly.
vdgmarc
Post by vdgmarc »
I thought to that as well, but in the logfile, you can see that it is a command by the ECU. Meaning that it's not a misfire, unfortunately.
You should still try this in a known working vehicle.
