SManager 2.8.9
SManager 2.8.9
SManager V2.8.9 (14 May 2025)
  • [S300 V3] Firmware version 24
    [S300 V3] Fixed S300 Bluetooth address not displaying correctly
Download here
Please only reply to this thread with issues & questions specific to the changes in this release. For all other problems start a new thread under the appropriate vehicle category.
ntanholt@icloud.com
Re: SManager 2.8.9
Post by ntanholt@icloud.com »
I can’t download Smanager on the hondata website every time I click download it takes me back to the home page with no other windows or download instructions
Re: SManager 2.8.9
Should work now.
Iceman
Re: SManager 2.8.9
Post by Iceman »
There seems to be major issues with connecting to s300v3 bluetooth to mostly all of the laptops i have tried, from bluetooth address (mac) not showing at all, to not showing correct address as the same as the s300's, I can confirm the bluetooth works when i use a mobile version (so that eliminates the s300v3 unit itself), but that isnt any use when needing to tune and not solely just monitor things, I have tried two laptops using win 10, one of them previously was being used to tune over bluetooth but now cannot even connect to it anymore, two others using win 11, one a surface pro 7 and other a lenovo thinkpad both cannot connect, i have also looked into the bluetooth stacks but this doesnt seem to work either, sometimes you can connect (pair) but it does not stay connected even after pairing to the pc and seeing the correct mac address in the smanager it still does not connect, id really like to rely on this functionality to mostly check over maps and adjust on the fly instead of needing to usb connect everytime, although this is the standard method i do want to utilize the bluetooth ability thats built with it, honestly i have had this issue now for maybe a year or so and waiting for a fix on every software update or firmware update but everytime no luck, even with this version i have no luck with it still, I hope your efforts can be focused on getting this issue solved and would love to hear if others too are experiencing this problem and if not to try it and see they have the same issue to better help identify and thus correct the problem, Thanks for your time, Regards.
abourmaian
Re: SManager 2.8.9
Post by abourmaian »
Hello, I noticed on the S Manager, K Manager, and Flashpro Manager programs that they are all set to expire on October 29th 2026.Will a update be released soon to extend the expiration date on all three software's?
Re: SManager 2.8.9
This should not be an issue for you
