hondata fuel pump question
rainy187
Post by rainy187 »
I post the question here is because i use flash pro, i can't find any where else to post this question.
i installed the hondata fuel pump kit for my 2018 accord 2.0 AT yesterday, and went for a test drive. toward the end of the test drive the engine stalled, after i parked my car and try to crank, it won't start. However, after i power off the car and start it again, the car can start.
i have attached the log, i can see all of sudden DIFP went to 0, can anyone tell me what caused this please
sunday problem.fpdl
Re: hondata fuel pump question
What kit? The low pressure fuel pump?
rainy187
Post by rainy187 »
yes, the low pressure fuel pump kit
Check the installation of the pump to make sure that it is getting fuel
rainy187
Post by rainy187 »
Yes I did read the instruction, and checked the log (log attached in the previous post)
and I can't figure out why this happened, I am hoping this won't happen again, especially on the freeway.
Lets say if this happen again, then what should I do?
Inspect the pump, check the wiring connector and the o-rings in the pump outlet are installed correctly.
rainy187
Post by rainy187 »
It happened again, and the log file is attached.
is it if the wiring is not connect properly, then the pump will not function at all? it was the spacer + two O rings and pushed in all the way, if it didn't go in all the way then the cap will not lock into the place.
should I ask for an exchange?
replied via email
