Base map d16y8 turbo 850cc injectors
hi im looking for someone that can send me a base map for a d16y8. im getting a tune in few weeks but i need something temporary that will be a little rich so i can make sure this thing is building boost, and something that has some safe timing so i can break it in thanks
d16y8 with SF rods , carillo pistons
stock head and pulley cam skunk2
850cc injectors
3" exhaust
38mm wastegate
skunk2 manifold
T3 PSR 3067 turbo
850cc injectors
3" exhaust
38mm wastegate
skunk2 manifold
T3 PSR 3067 turbo
- CalibratEd
- Contact:
Re: Base map d16y8 turbo 850cc injectors
Have you tried reaching out to your tuner for a base map?
-Ed
-Ed
Instagram: calibrated.tuning
I don't have a tuner
- CalibratEd
- Contact:
Gotcha. I assumed you did since you stated “ im getting a tune in few weeks ”.
-Ed
-Ed
I meant that I would find one when it was ready and the car could be taken out of the garage.
For now I can't go out of the garage, as soon as I touch the throttle, stalls
That's why I need a minimum map so that it doesn't stall and can go at least 50m outside.
- CalibratEd
- Contact:
Post the calibration you are running and a datalog. I can take a look at it. Have you applied the proper injector data? Do you have a wideband installed?
-Ed
-Ed
Calibration, is stock " d16 p28 " from S-Manager i only put 850cc in injectors paramètres
- CalibratEd
- Contact:
Gotcha. Do you know what brand the injectors are? Are you running a wideband?
- Ed
- Ed
hi , yes Aem x series wideband and injectors specifications :
EV14 Injector, 12 Ohm, 870cc, C25, Jetronic (EV1), O-O 34 mm, Short, Long Spray End (EV14-870, Bosch 0280158209)
Maximum flow approx 870cc @ 3 bar
Short type injector (O-ring distance is 34 mm), long spray tip
Compatible with E85/RE85 and gasoline
14 mm O-rings, compatible with ethanol and gasoline
Jetronic (EV1)-type connector
High resistance
6 hole spay tip
Conical type spray
High resistance
6 hole spay tip
Conical type spray
- CalibratEd
- Contact:
Post the calibration you a running with a datalog. I can take a look at it.
-Ed
-Ed
hereCalibratEd wrote: Wed Jun 11, 2025 8:03 am Post the calibration you a running with a datalog. I can take a look at it.
-Ed
