8th gen FBO hybrid racing, 3” thermal r&d and plm headers
mrspades252
I know Ill have to get it tuned eventually but I was wondering to see if anybody has a calibration or something similar?
- CalibratEd
- Contact:
Re: 8th gen FBO hybrid racing, 3” thermal r&d and plm headers
Run a Hondata base calibration with the mods closes to yours until you can get it tuned. I can check how it’s running if you post the calibration and a datalog.
-Ed
-Ed
Instagram: calibrated.tuning
mrspades252
Will do ASAP, i actually took my suspension apart and will be installing coilovers! Thanks!
- CalibratEd
- Contact:
No problem. Sounds good.mrspades252 wrote: Sat May 24, 2025 4:24 pm Will do ASAP, i actually took my suspension apart and will be installing coilovers! Thanks!
-Ed
mrspades252
Alright Ed, i ran into a lot of issues over the past few weeks with this car since i posted. Old suspension were seized, and had idle/drivability issues, which prevented me from replying back! I finally got the coilovers installed and fixed the idle/drivability issues (replaced maf sensor)! I will start datalogging on saturday but am unsure on which calibration to use! Will you still be able to give me a hand?CalibratEd wrote: Sun May 25, 2025 8:07 pmNo problem. Sounds good.mrspades252 wrote: Sat May 24, 2025 4:24 pm Will do ASAP, i actually took my suspension apart and will be installing coilovers! Thanks!
-Ed
- CalibratEd
- Contact:
Sorry to hear that. Like I said prior, select a file with mods closes to yours and I can let you know how it’s running.
-Ed
-Ed
mrspades252
How should i datalog? Locally and on the freeway?
- CalibratEd
- Contact:
Both are fine. Just refrain from doing any wide open throttle pulls.
-Ed
mrspades252
this is the calibration i used
here is a datalog!
here is a datalog!
mrspades252
heres another datalog
- CalibratEd
- Contact:
The fueling is not far off and you do not have any knock.
- Ed
- Ed
mrspades252
Awesome so i should be able to drive it around for the time being until i can get it dyno tuned?
- CalibratEd
- Contact:
