Launch control question.
Janz3n
Post by Janz3n »
Is there any way to turn off the launch control rpm and back on without a PC and reflashing ? Reason I ask is for drag racing. I'd like to be able to use higher rpm to do a burn out and then have my launch rpm set much lower. Or is there any kind of work around?
arivince08
Re: Launch control question.
Post by arivince08 »
Sadly no , I tried to in the past before but nothing worked for me . You would have to get hondata (preferably) or k tuner to be able to adjust launch control at will . And when you do get hondata and reflashed , it’s simple as pressing the clutch and pressing the + or - on the steering wheel . You hold the clutch and press “cancel” on the wheel to see where your launch control is set
Complete details are in the help file at: https://hondata.com/help/flashpro/launc ... sub=launch
