ECU Pin type
Boosted_Muffin
ECU Pin type
Post by Boosted_Muffin »
Hello there!
My first time posting so I apologise if this is in the incorrect place or if this has already been answered before, I have searched as far as my patience will allow and haven't found a solid answer....
Would anyone know what the pin type is for obd1 ecu's?
I have a 92 civic D15b7 with an S300 installed, up until now any extra inputs I have added have just been via a wire jammed into the terminal... Which is obviously not ideal...
Now I've added an AFR guage and wired the wideband into the ecu I would definitely like a more reliable solution....
So would anyone know what the individual connectors within the terminal are called so I can purchase some and wire everything more permanently?
The only options I have found are entire connector kits, which is just a waste if I only need 2 or 3 pins, or one place in the US that sells individual pins but for a ridiculous shipping costs to deliver here in France... and they don't specificfy what they're called so I can't search elsewhere....
The only details they show are "long" or "short" type.
I believe it's the short type for the "D" connector which is what I require.
Thanks in advance!
Re: ECU Pin type
Boosted_Muffin
Re: ECU Pin type
Spunkster wrote: Tue May 27, 2025 12:40 pm You might try https://www.hamotorsports.com/collectio ... ZMJ4-Ajlge
Thanks for the reply.
This is the place I found initially
But for example... To get one pin shipped to me, the pin itself is only 98cents, but 35$ delivery....
That's why I was hoping someone would know what they're called so I can find some more local
