upload issue
Civic 2016+ 1.5 Turbo
srdunn240@gmail.com
upload issue
Post by srdunn240@gmail.com »
I have gotten myself into a pickle not knowing what I am doing. I have a 06/18 Honda civic 1.5 turbo cvt with multiple mods im trying to tune and somehow i have managed to start out with a 2017 base map and it wont let me change it from a 2017 file to a 2018 file. i am having hill assist codes come up and other things making me think that I am not on the right base map. When i try and upload the calibration it says " you cannot upload a civic 1.5T us 2018 touring cvt calibration to a civic 1.5t us 2017 hatchback ex cvt flashpro". I also need help figuring out exactly what base file to use because i don't know these newer Hondas well at all. Its an 06/18 honda civic hatchback with the 1.5 turbo and cvt....thats all i really know lol. any help is highly appreciated and thanks in advance!
Re: upload issue
What is the FlashPro serial number?
srdunn240@gmail.com
Re: upload issue
fp-16civic-l15t-205693
srdunn240@gmail.com
Re: upload issue
Spunkster wrote: Thu Jun 05, 2025 1:11 pm What is the FlashPro serial number?
did I get the wrong one?
Re: upload issue
With everything plugged in and the ignition in the on position, click on the New Calibration button at the top of the screen and it should default to calibrations compatible with your vehicle. Select the one you want and upload it to the ECU.
srdunn240@gmail.com
Re: upload issue
Spunkster wrote: Mon Jun 09, 2025 9:18 am With everything plugged in and the ignition in the on position, click on the New Calibration button at the top of the screen and it should default to calibrations compatible with your vehicle. Select the one you want and upload it to the ECU.
i just went out to the car and tried it, made a new base file and it pulled up the one i want/need to put in but wouldn't let me, said the same thing.
Re: upload issue
srdunn240@gmail.com
Re: upload issue
Spunkster wrote: Mon Jun 09, 2025 3:46 pm With everything plugged in and the ignition in the on position, go to the Help menu and click on “send feedback”. Include a detailed description of the issue.
done.....thank you sir!
