K24a into 05 RSX-S
Grs22
K24a into 05 RSX-S
Post by Grs22 »
Hello, I am looking for some insight on this swap. I want to help a friend out with his build The car has a k24a (basically k24a2) swapped into 05 rsx type s, the mods are:
-aftermarket exhaust, headers, intake manifold adapter with prb intake , stock rsx-s Throttle body, stock rsx injectors and fuel rail, 05 rsx-s transmission, kpro v4 (PPL ecu)-wants to install a skunk2 intake
- he says the car drives fine on the stock rsx-s ecu but when he loaded a base tsx map the car started acting up, not shifting properly, drove like crap…
Should he switch to stock tsx RBB manifold instead of PRB?
How do I help him to get the stock tsx base map to work properly? I hear some people experienced knocking due to running lean so do I adjust fuel/run a closed loop on kpro
Is it possible to daily drive with stock tsx base map safely? can he drive it fine with out a professional tune ?
is anyone willing to share a tune that would work for this setup ?
Re: K24a into 05 RSX-S
You can try different calibration to see what works best as a starting point, but it will probably need custom tuning on the dyno.
Shifting should have nothing to do with the calibration as it has no control over the transmission.
CalibratEd
Post by CalibratEd »
I suggest you start with a stock TSX calibration and adjust it accordingly. If you post the file and a datalog I can help get it to run safe until you can get it properly tuned.
-Ed
Instagram: calibrated.tuning
