Issues with onboard datalogging
tsteinhart15
Post by tsteinhart15 »
Ran into some frustrating issues when datalogging with my Flashpro Mini. Just recorded 4 separate logs and when I got home and tried to download them to my laptop, the logs would not save to my computer even after completing the green download bar as normal. I also tried to use the download button instead of "Save as", and that made all 4 logs vanish from the datalogging tab. I was able to get them to come back by unplugging and replugging in the flashpro to my laptop, however I am still unable to download the logs. Decided to delete these logs and start over, and now I noticed that the datalog light no longer flashes constantly while recording logs. It will go solid blue for about 30 seconds, then turns off.
Serial #: FP-2012Si-320283
Re: Issues with onboard datalogging
tsteinhart15
Version 4.4.9.0 build 4944
I believe its the latest beta version
tsteinhart15
ok done
