K pro ecu compatibility
I’m doing a k20a2 swap into an eg civic. I been gathering parts here and there. I picked up a conversion harness off a guy and he had a Kpro ecu he said was for a k swap k20a2. So I grabbed. When I got home I realized the ecu part number is not the same as the ecu i have from my k20a2. My ecu not k pro is 37820-prb-a06. The k pro ecu I got from him is 37820-ppa-a54 (kpro 67089). Will this work for my k swap or do I need to get the prb ecu?
MondeCruel
Re: K pro ecu compatibility
This ecu is mentioned here https://hondata.com/tech-alternative-ecu-engine-swap
Ya I read that already. Just still wasnt sure if it would work for me.
Are you confirming that it will work or just sending it for the information?
MondeCruel
It was just for information but from what i can read it will work, you just have this VSS modification
