Need help setting base map to get Turbo 2k12 civic Running
Khalid1fastEg
Post by Khalid1fastEg »
Hi guys new to the flashpro community. I have my 2k12 Si boosted right now and barley runs with flash pros only turbo charged base map calibration. Currently using the 1000cc precission flash pro base map with all o2 sensors disabled and afm switched to Map Cal.
My set up is stock k24z7 engine
Garrat gtx 3076r turbo
Side winder turbo manifold
Tial WG
1000cc D.W. injectors w/ pig tails
Skunks 2 pro series manifold
Skunk2 fuel rail
Zdx tgrottle body
3in turbo down pipe
It'l idle very rough with current base flashed on it. And run supper rich like a smoke cloud of fuel if i even tap the gas pedal it died eight away
Thanks in Adance guys!
CalibratEd
Re: Need help setting base map to get Turbo 2k12 civic Running
Post by CalibratEd »
Did you apply the proper Injector data? Post the calibration you are running with a datalog. I can look it over and let you know how its running.
- Ed
Instagram: calibrated.tuning
