Pin E1 issues KPRO
Zsuch
Pin E1 issues KPRO
Post by Zsuch »
Hi I have a 1991 Honda Civic that im swapping a K24A2 in. The issue im having is that the fuel pump doesnt prime when the key is in IGN ON ENG OFF position and I cant hear the main relay click either. The motor just turns over. I followed hybrid racings instructions on wiring the conversion harness properly. I wired E1 from the conversion harness to the main relay ground wire on the OEM chassis harness. I tested the wiring that on E1 to the main relay and saw that it is receiving 10v. Knowing that this is a ground signal I was a bit confused why it was receiving 10v. I ran a wire from the relay that leads to E1 to a grounding point and then the pump kicks on. I checked wire that leads from E1 to the relay and its good. Why do I need to ground E1 externally for the fuel pump to kick on? Is it possible that I may have caused some damage to my ECU. Thanks in advance for the help.
Re: Pin E1 issues KPRO
Try the ECU on a known working vehicle and see if it works as it should. If it does not, then the ECU has been damaged and would need to be replaced.
Zsuch
Post by Zsuch »
Okay, I will try that. Thank you!
