s300v3 issues
Mrgeers
s300v3 issues
Post by Mrgeers »
- serial number of the s300 inside the ECU
32210
- version of software being used (Help, About)
Version 2.8.9.0 Build 4941
- the calibration (as an attachment)
geers rev 26-5.skl attached
- a datalog of a problem (as an attachment)
Do not have a datalog because the issue causes no start (no power to s300 board
- what sort of vehicle you have
2000 Honda Civic Hatchback
- what sort of ECU you are using
P28 (it is an older board, caps were leaking)
- anything about the car which has been modified from stock which may affect the ECU (don't include what sort of rims you have nor stereo etc).
b18c1 82mm with p30 pistons and Skunk2 Tuner2 cams
- a specific description of the problem
When s300 is plugged into board it is showing signs of a short on an engine simulator and shuts off any functionality. No lights to s300 board either. When the s300 board is removed, signs of the short go away. We attempted this in three good ecus, all showing same problems. (all these ecus have been repaired and capacitors replaced).
Re: s300v3 issues
Have you plugged a socket tester into the ECU to see what lights show on the socket tester?
Mrgeers
Re: s300v3 issues
Post by Mrgeers »
PCS is orange
VTS is blue
ICM is yellow
All injectors are solid green
No other lights are on
Re: s300v3 issues
Mrgeers
Re: s300v3 issues
Post by Mrgeers »
We did not plug one of those in. We have the engine sim plugged into the big plug
Re: s300v3 issues
A socket tester should be used to see if all the lights come on as they should.
Mrgeers
Re: s300v3 issues
Post by Mrgeers »
A digital voltmeter is used to test all the trace and dims on the board.
The lights go down when you plug the Hondata in indicating a short and gives no injector pulls or ICM it just kills the ECU.
The ecu boards are good. We put other hondata chips in and everything works.
Re: s300v3 issues
No datalog was attached to the original post
Mrgeers
Re: s300v3 issues
Post by Mrgeers »
There’s no light on the board. I cannot get a datalog
Re: s300v3 issues
Send and email to support <at> hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
Include a link to this thread
