CANFlex
Captainslow
CANFlex
Post by Captainslow »
Hi There,
I was using the calibration "Accord Turbo 2.0 AT Touring 2018, high octane, CTR turbo with Enable Flex Fuel with base settings option". I installed CANflex and I switch the ethanol EC2 analog voltage option to CANFlex under the Ethanol section. Is that the proper way to get the must of the calibration or should I be using the "Accord Turbo 2.0 AT Touring 2018, CANFlex, 49 State, E0-E80 +6psi" instead.
Please let me know.
Re: CANFlex
If you have a different turbo and have tuned it then you should just change the setting to use CANFlex instead of the ECT2.
Captainslow
Re: CANFlex
Thanks for the prompt response
