Please Review - Data-logs Misfire Issue Urgent
Hondatuner_1
Post by Hondatuner_1 »
Vehicle has for some reason developed misfire under load at times. At times will cause vehicle not to start but eventually does. I have checked mechanical and electrical components. The sputtering occurs at low throttle rpm. Please review and pinpoint any outstanding flaws. Any leads will help !
Hondatuner_1
Re: Please Review - Data-logs Misfire Issue Urgent
here is more data-logs and for whatever that it may be worth, symptoms occur at idle after long load interval for some reason ... please help
Dexorcist
Post by Dexorcist »
Failing TPS sensor
