Adding aem wideband to kpro
jtr316
Post by jtr316 »
Hello I have a 06 base rsx with k24a tuned with kpro. I don’t believe the car has a wideband installed but it does have a tune. If I installed a wideband will I need to get it retuned?
Re: Adding aem wideband to kpro
No, it would not need to be retuned unless it is poorly tuned at the moment
jtr316
Post by jtr316 »
Thanks for your reply.
If the car is running both factory sensors will it run any different if I installed the aem gauge? It’s a 2006 rsx base, I’m using kpro/pnd ecu from hamotorsport
Thanks!
It shouldn't change
