Vtec settings
FlashPro questions & answers specific to the 2007-2008 Acura TL
reallyflyguy
Vtec settings
Post by reallyflyguy »
Lets see if I can state this clearly.
I have Vtec set to lower 4850 and upper 4850
when I'm cruising and holding the rev 3k-4k I see and VTS turn on and feel the car hesitate from the air flow being all wrong.
I've had the setting for map set 4.311 across all rpm and I've moved them down to 0.850...I've even dropped lower to see what happens.
I can't stop vtec from kicking in.. on the flip side it activates exactly as should when I'm on throttle..
I feel like something is missing like a manual rpm setting... avoiding map settings
Re: Vtec settings
Post the calibration used as well as datalogs showing the issues.
reallyflyguy
Re: Vtec settings
Thanks for helping.
I loaded 2 data logs.
The low speed is where Vtec is turning on unnecessarily.
The second to show it works normally.
Re: Vtec settings
When you upload to the ECU how long does it take to upload?
reallyflyguy
Re: Vtec settings
I've never timed it but I would guess 2 to 3 minutes.
I can time it if you need
reallyflyguy
Re: Vtec settings
ok, I was bored and trying some stuff.
it takes 1:45 seconds to upload the tune
reallyflyguy
Re: Vtec settings
any updates?
Re: Vtec settings
You probably need to set the VTEC at a higher RPM for lighter throttle conditions instead of having just one RPM point for
VTEC to engage no matter what the load.
reallyflyguy
Re: Vtec settings
Ok
I've set all my lower RPM map values to 0.950 to 0.900
Vtec lower 4400 and upper 5000
road tested again and vtec still pops on at 3800 under light throttle
Re: Vtec settings
If you set the rev limit to something low like 2000 RPM, does it rev limit at that RPM?
reallyflyguy
Re: Vtec settings
flashed it and Yes, it does work
Re: Vtec settings
If you return to stock from the online menu, what does the VTEC do?
reallyflyguy
Re: Vtec settings
I flashed back to stock and YES the problem is still present. I'm stumped. This is so simple. The ecu shouldn't engage the VTS like this
Re: Vtec settings
I don't think this is the ECU causing this as it is still doing it when returned to stock and no one else is having this issue. IS anything else wired into this vehilce?
reallyflyguy
Re: Vtec settings
I have a AEM wide band installed on the ELD circuit. I'm going to unplug it to see if it acts differently. Possibly it's back feeding into the ECU?
