Help for fuel pressure sensor in analog input..
Bowo gono
Post by Bowo gono »
Hello Honda, I added an external sensor, a fuel pressure sensor, for data og.
The diagram follows the instructions:
Black to B2
Red to D19
Signal to AN0
After I did everything, the value in Smanager shows no change and remains at 10 bar.
Sensor installed, value 10 bar
Sensor not installed, value 0 bar
Is there a solution?
Re: Help for fuel pressure sensor in analog input..
Post the datalog showing the issue.
Bowo gono
Post by Bowo gono »
datalog
Bowo gono
Post by Bowo gono »
Problem solved bad sensor
