tuning lambda in neutral?
Honda_TypeS_10
Post by Honda_TypeS_10 »
Is it okay to check lambda values to adjust accordingly when my car is in my garage in neutral and revving to the specified RPMs or is this a BAD idea?
Re: tuning lambda in neutral?
That is not a good way of testing. It should be done while driving under laod or on the dyno.
Honda_TypeS_10
Hi Spunkster,
Thanks for the fast response.
I have a 2010 Civic Si running a MAP tune. For dialing in fuel LOW and fuel HIGH, can I start off by disabling VTEC for the fuel LOW and drive around the block to change the lambdas? Is that the correct way?
Thanks again.
Yes, you can do that.
Honda_TypeS_10
Thank you, I will do that!
