Vtec Killer Map B Series
Steeve_Civic
Post by Steeve_Civic »
Hi,
Would you mind help me to configure in the S300 to disable Vtec please ?
What do you advise on SManager to be configured ?
Re: Vtec Killer Map B Series
On the VTEC tab of the parameters window, uncheck VTEC enabled.
Steeve_Civic
If I'm on Vtec Killer and uncheck VTEC, that's mean I will stay on low speed map ?
And what could be the issue to stay on the Low speed map ?
correct. Staying on the low-speed map with cams and valve train note designed for high RPM operation could cause damage.
