unlock issue
paulom
unlock issue
Post by paulom »
Flashpro # FP-SI-US-237371
CIVIC SI 2006-2011
The car is a Civic Si 2008
The flashpro can be locked and no calibration can be loaded on the car, it freezes after 10 seconds.
After some attempts, using other note, other USB, other cable, no cable, I tried to unlock and the message is that "the car is not the same flashpro was locked " etc etc"
The ECU is a 37820-RRD-M11
Then I looked at Flashpro properties, under ECU, right after the correct VIN,
the calibration ID is 37805-RRD-M110.
CVN 0X4EEC3628
BINARY CIVIC SI 2006+ SOUTH AMERICA
Is it the problem?
How can I fix it ?
Is it a flashpro problem or a ECU problem ?
I´m a dealer at Brazil.
Thanks !!
Re: unlock issue
