300v3 wideband digital input
365motorsports
Post by 365motorsports »
i have a aem 30-4100. do you just wire the correct wires to the s300v3 board in the digital inputs? rx and ground? are there any other settings that need to be selected or changed after selecting the wideband in the drop down menu?
365motorsports
Re: 300v3 wideband digital input
You need to make sure you set the wideband in put correctly for the wideband and input you are using.
365motorsports
do i need to make any changes to the instance number? i selected the correct wideband in the drop down menu
I don't know what you mean
365motorsports
this is what i am talking about
For each channel the channel type (typically wideband for single channel inputs) and unit may be selected. With the PLX since it is possible to have multiple channels of the same type (eg 4 channels of lambda, or 4 channels of EGT) an instance number can be set. The instance number is set by the PLX device based on the order in the daisy chain. eg the first unit is 0, the second is 1 etc. Note that this only occurs when multiple channels of the same type are present in the chain - normally the instance will be zero.
https://hondata.com/help/smanager/digit ... ub=digital
You shouldn't need to if there is only one device.
365motorsports
Thanks for the info. Does the digital wideband input for a Aem wideband very accurate? No offset needed for it to read correctly?
I do not have any experience with AEM widebands.
365motorsports
how do you apply the digital wideband input to closed loop advanced? doesnt give you a option for that in the drop down menu
The only way to use an aftermarket wideband for closed loop with an s300 is to use the analog inputs on the actual ECU , not the digital or analog inputs on the s300.
