S300 V3 no lights
JosiahFaison40
S300 V3 no lights
Post by JosiahFaison40 »
Car: 1999 Honda Accord EX 5spd
ECU: P28 with all capacitors replaced
S300 serial number: 67277
Mods: Ghost key push button, air intake, full speaker system
Issue: installed s300v3 onto the p28 and hooked it to my car. At first the s300 was turning on fine and I uploaded my tune to the car. Went to go finish my install and start the car but the s300 won't show any live data. At this point I could see the green lights (D4 and D3) on the s300 but D2 was flashing red rapidly. I figured it was the ECU connection with the s300 so I took it off and tried to align it better. I know the s300 is on there correctly now but when I hook it to my car I'm getting no lights on the s300 at all now. I checked the ECU fuse already and it was good. I tried to unplug everything and plug it all back in but that didn't work either. Also I'm hearing some weird clicking near the radio/climate control area. This ECU doesn't have a J12 capacitor. If I plug my original ECU back in the car works no problem
JosiahFaison40
Re: S300 V3 no lights
Here are some pics on the ECU
What is the battery voltage at the ECU measured with a multimeter when cranking?
JosiahFaison40
I didn't even get to the cranking stage I couldn't get the s300 to power on correctly. I sent the ECU and S300 to the person I bought it from to test my combo. I'm gonna see what they say before I test any further.
JosiahFaison40
Had my ECU and S300V3 set up tested, and it came back completely normal. I think there is something wrong with my car's wiring that is causing the issue. Once I get my P28 back in the mail, I will troubleshoot further. Also, I don't think the ECU is losing power but the car is rejecting the ECU after the first on-off cycle.
JosiahFaison40
Spunkster wrote: Mon Aug 11, 2025 9:21 am What is the battery voltage at the ECU measured with a multimeter when cranking?
Got my ECU and S300V3 back and nothing was wrong on the ECU end so it has to be my car's setup. I tested the power at the ECU connector and I'm getting 11.8V so it's definitely getting power. My S300V3 still won't turn on. Not sure what to do now....
Cam.Ray
Post by Cam.Ray »
Any update? Having the same issue brand new everything and professionally refurbished ecu.
