K20a2 with Dragcartel 2.2 endurance cams help
Eliud Lisboa
Post by Eliud Lisboa »
This is my setup
K20a2
Ported head,intake and exhaust
Ferrea 6000 std size Valves
Spring and retainers supertech 95lbs titanium keepers
Drag cartel cams 2.2 endurance
Pistons Traum 11.0.1 for turbo 86.5 bore
Manley turbo tuff Rods
Sidewinder turbo header manifold
Rbc ported intake
72mm Throttlebody skunk2
With idle valve working
1000cc bosch injectors
New timing chain and new modded tensor
New oil pump Oem Type S honda genuine
Superdamper harmonic balancer
I need help with the tune i want to make a safe basemap for engine break in..without the turbo making psi
I have the intercooler piping disconnected
Any help will be much appreciated 🙏
Eliud Lisboa
Re: K20a2 with Dragcartel 2.2 endurance cams help
thease are and update with new ignition tables recomended for 2.2 drag cartel cams
CalibratEd
Post by CalibratEd »
The car has 3 counts of knock which is not too bad but still needs to be adjusted. The car is running lean in the higher RPMS.
-Ed
Instagram: calibrated.tuning
